I have just loaded MicroStation PowerDraft CONNECT select Edition - PC - Microsoft Windows 10. Research for hours, but can't find the right answer and have been trying different ways.
I am trying to configure the software to print the PDFs to match the drawing name. Tried editing the pdf.pltcfg in the PRINT dialog box, but it's a READ ONLY file.
Why is this READ ONLY?
So I tried editing in NOTEPAD, but I don't have permission.
Why don't I have permission to edit my pltcfg file?
Is this something that should be changed in 'Configuration Variables'? I am thinking NO.
This is the line in the pdf.pltcfg file that I think should be edited....
<DefaultPrintFileName>$(MS_PLTFILES)$(basename(_DGNFILE))-$(MS_PLTMODELNAME)<autoInc?prefix=-?digits=3?base=0></DefaultPrintFileName>
I tried this ... <DefaultPrintFileName>$(MS_PLTFILES)$(basename(_DGNFILE)) BUT got the word DEFAULT at the end. "a2_1First-Default.pdf"
Thank you!
Thank you both. However, I have done this with the file but will try again.
Best,
Lynn Taylor
Residential Designer
Taylor Made Plans
615-650-8956 office
www.taylormadeplans.com
lynn@taylormadeplans.com
