I figured it out.
Here was my solution or one way to do it. I wanted to print a black and white pdf with the R/W line being a red color.
1. I created a new pen table. (In the print dialog, click >> Resymbolization >> New Pen Table >> Save (A modify Pen Table dialog appears).
2. In the "Modify Pen Table" dialog, Click Edit >> Insert New Section Above >> Give it a name (Non Color)
3. In the "Element Selection Criteria" tab under "Color option, specify the range of the color from the color table you want to stay non-color. Exclude the one you want stay color (67).
4. In the "Element Output Actions" under the "Color" option specify it "By Index" as 144. This is the grey color you want everything to be except 67 which is naturally Red.
5. When you print, Make your set the color option as True Color and you new Pen table with grey out everything except the color 67.
You shouldn't delete this post instead as a service to others with a similar problem users will search here or with google so if you solved it you should do a reply or edit your own post and put in the solution so it will benefit other users with similar problem after all you found the solution then make it easier to find for others .. that's how we build up solutions here for everybodies benefit .... some are very old solutions 10 years plus but they still work.. please do not take this as a criticism or dressing down, I'm just asking everybody in general to share results to build up the body of answers in these forums...
Lorys
You are correct Lorys. At the time I thought It was a simple question and didn't want to spam the board. I had asked another question that same day I think. :)
