Hello community,
I'm doing roadway striping plans. I've referenced in the base files at 40 scale. Horizontally It captures the right length I want of my sheet model (Let say 400' so).
Vertically I want to exaggerate the roadway so It'll be better for other people to see. Is there a way to do it. I tired scaling the reference files but it
will scale both x and y axis. I don't want to add more sheets. I just want to scale the y axis of the reference files/base files. Thanks for reading!
There is a reference attachment setting that will let you treat a reference file like a regular element (like a cell) I believe the tool is called "Treat as Element for Manipulation". If you toggle that on for your reference, you will then be able to use the regular MicroStation scale tool, which will allow you to use an unequal scale factor.
MaryB
Answer Verified By: RickyT
Very nice Mary B. Exactly what I was looking for. Thanks alot!!!
You're welcome! I'm glad I could help!
Could you please click to accept this answer? That will let other people who might come across this thread later know there's a solution.
