Microstation crashes when trying to print
Hi everyone.
 One of our employees’ microstation crashes as soon as she tries to print.
When you click print the print dialog does not even open, instead it freezes a little bit and then opens the send error dialog, if you close it, it opens another dialog where you can choose abort, retry or ignore, I will attach screenshots. If you pick ignore it opens a partial print dialog box, where you can change settings but can’t preview nor can you print. I have tried reloading the print driver, replacing the print driver, replacing the workspace folder, uninstalling and reinstalling the software( well not all of the modules - i will try doing this in the meantime) , nothing works.. It crashes with a send error dialog and then it creates a log file in the temp folder which I have attached.
We are using Microsation selectseries 10, she is logged into the connection client with a functioning license for Microstation.
Version: 08.11.09.916
Connection client version: 10.00.18.13 (im scared of updating because the newer version was causing the connection client to say something is wrong with your connection and then it wont work)
 3107.exception.log
