Printing in back over a raster Image
Good day all,
I have a peculiar issue here that I cannot figure out.
I have a drawing that has a raster image as the background. Now, I have two text elements. One appears with a white background in the paper space, which is more desirable for me, and the other does not.
I am not sure what property the other has that the one does not.
The image above shows how they both appear in the default model.
The image below shows how it would appear on the paper space, where the text with the white background is more readable than the other.
Has anyone ever come across this, I am unable to figure out what the issue is.
I am using MicroStation V8i SS10, version 08.11.09.916, running on Windows 10
I have attached the sample .dgn file as well.
Thank you.
.Text Printing sample.DGN
  • The text on the right has background set to BG, which is the background color. Black in the default model, white in the sheet. The other text has no background set.
    The fix is more involved, since most of the the text is Style Working, if you change the style,then save it, it will change all text style Working texts. Or you can adjust one at a time, or you can create a new text style.
Reply
