Using Print Organizer, when attempting to add a particular file, the following message appears.
I have defined Print Styles that searches a reference file to apply a fence shape according to color and weight of the shape. Issue is specific to this one particular design file.
Anybody have any ideas?
Microstation V8i (Select Series 2) - Version 08.11.07.443
Terry
What is different about that file? Are there duplicate elements, or is it looking at a different reference file?
While I suspect there's something different going on with that one file I have, on occasion, run into files that just don't want to print. On those occasions I usually just have to save off the bad file and recreate it.
MaryB
I have removed the few duplicate elements contained in the file. Tried to batch print again and still same issue. All the files I am printing has the same reference file attached that holds the border sheet shape file that Print Organizer searches for. I failed to mention that I also have the following message appear as well....
OK, I've never seen THAT before... :-OAnd it's only one file?
(Assuming you've exited MicroStation and reopened it) Does the file print correctly if you place the fence manually and use the regular Print dialog?
I think that file just may have bad data in it. I can't say why that might be or how it happens. But I have seen files every once in a rare while that just will not print with Print Organizer. At that point, my workaround has been to either stick a blank placeholder into my PSET so that I can print that one file individually, or to recreate the file from a clean seed file. I can usually reference the bad file into the new file and copy anything I need out of it without bringing over whatever was bad.
If you can, file a Service Ticket with Bentley Support and send them this file (and supporting files). They may be able to find what the problem is and maybe even fix it.
I recreated the file and had no problems printing. There must be something in the file that is corrupt. This happens from time to time so I really want to figure out what is causing this. I will file a Service Ticket.
Thank you for all your help.
You're welcome.
If they can figure it out what the problem is with your file, let us know. It doesn't happen often here, but it does happen, and I'd love a better idea of what could be causing the issue.
