I have ran into a print organizer issue I havnt been able to solve yet. We have a 3D reality mesh from a Projectwise web connection that is referenced in as background for our 2d plots. When I use the print dialog it prints fine with the model showing up as an image but when I use the print organizer to print the model doesnt show up. I have set the print settings to be the same between the two different ways and tried many other combinations, including rasterized, in the print organizer properties window but haven't gotten it to work properly. Any insight would be appreciated.
Example From Print Dialog:
/resized-image/__size/500x291/__key/communityserver-discussions-components-files/19568/83671.Capture.PNG
Example From Print Organizer:
/resized-image/__size/500x750/__key/communityserver-discussions-components-files/19568/Capture2.PNG
Print Configuration File:
/cfs-file/__key/communityserver-discussions-components-files/19568/PDF_5F00_ss3v8i_5F00_pdf_5F00_Mndot.pltcfg
Thanks! Brad E.
Windows 10 - MS Connect Edition Version 10.15.00.74
