Is there a way to permanently change your Microstation printer to pdf preferences? I would like my resolution to change from 1200 dpi to 300 dpi automatically when printing out drawings to pdf, as this would save a lot of time when printing out many sets of drawings individually. I currently manually change it to 300 dpi through the printer settings every time I have to print each drawing. Please let me know if this is possible. thank you.
How can you create proper pdfs with vector instead of some kind of glitchy vectorized raster?
I always get results like the following:
Autodesk tools do not ask for resolution and always create pdfs with decent readability.
like this:
Hi Andreas,Welcome to this forum.
HTH
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
Hi Ivo,
thanks for your answer.Rasterized is unchecked:
--> No change, still blocky pdf
When I try to alter the driver, there is no default output mode. What can be changed:
But still it looks like the picture in my first post.
I had something simular and this was the answer:
Text schlecht lesbar in Vektor-PDF
It's in German, but basically in the pdf.pltcfg file, you need to change:
Base properties tab > Driver Properties > Precision > Maximum
Save and close, and in the Print dialog you also need to reload the pltcfg (File > Reload Printer Driver Configuration) to make it work.
Windows 10 pro
OpenBuildings Designer Connect Edition Update 10.10.01.151
Did you notice a change in file size when you did this? How much bigger did your files grow (if at all)?
