I have a MVBA print event handler that uses the IPrintEvents interface. I use it to collect print information. When testing Microstation CONNECT version 10.15.02.11 there is a significant delay in the print preview window and also the plot file creation. When I unload the MVBA all works as expected. Is this a bug? Here is the MVBA file:
4011.PrintSetupConnect.zip
The purpose of this handler is to capture the full path of the print output file. This info is stored by Microstation in the variable MS_PLTOUT after you print. Without the handler this variable isn't defined. The supplied PrintEventHandlerExample.mvba from the MetroStation workset in the Example workspace produces the same delay.
Benzi Papo said:Does anyone have another approach to get that info?
There's a Plotting Forum where you may find a better-qualified audience.
Following further testing by Bentley Support a defect has been submitted.
