How to edit design script print? It's printing the background text all black. Using Microstation V8i SS10.
Thank you!
Lucilia
Hi Lucilia,
Lucilia said:How to edit design script print?
Design scripts are plain ASCII files, so you can use any editor (e.g. simple Notepad) to edit them.
Lucilia said:It's printing the background text all black.
To share the used design script can help to check (by somebody who knows Design Script features well ;-) why the background text is printed black.
To provide details like to what printer or format do you print and how text style is defined can help.
With regards,
Jan
ny_b_gray_color_util.pen
This is the pen table, I'm trying to use. Thank you!
This is how is printing
I'm guessing those are texts with background. Easy solution might be to change the background color in the file to 255,255,255. This is often easiest by printing from a sheet model. You could also modify all the text attributes to set the background color. Microstation does a little trick for black elements on black background, it will display them white.
isnt a pentable a ctb file and not .pen or is a design script file .pen
bobs right check your text style to use BG = 255,255,255 and the text to co=0
Lorys
