I have an issue when using Print Organizer from ORD. If I have multiple sheets brought into Print Organizer it only grabs about 80% of the Text nodes. For example, if I have 10 sheets 8 sheets have no issues but 2 of the sheets there will be nothing where the text nodes are located. The information is in the Sheet Model and if I print one of the sheets that had nothing in the text nodes as single print it prints fine.
Hi Philip,
We have a lot of issues with Print Organizer in ORD. Have you tried running Print Organizer in Microstation and get the same issues?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
