Being new to ORD (coming from SS10), when printing does ORD handle rendering raster images differently than Powergeopak SS10, or any other previous V8i version? I have a sheet model with a double plan view, each plan view has a reference file attached which has 6 aerial tiles attached to it via raster manager. Each tile is a .jp2 file of about 20 Mb in size. When printing to pdf, I set the brightness to 60 and the quality to 25%. This creates a pdf of about 3 Mb in size after several minutes.
When I open the pdf in Adobe, it looks like the aerials have been rendered in several smaller tiles. When I print the file, it takes about 10 minutes to print. If I create the exact same sheet model in SS10, print as a pdf with the same settings, the created PDF is about 1 Mb in size and prints very quickly when sent to a printer. I have also tried printing rasterized and non-rasterized, and it makes no difference. We have printed PDFs this way for years with no speed or size problems.
Is there a setting somewhere in ORD that I am missing which needs to be changed or adjusted?
Thanks.
Hi Lorys. Our pdf pltcfg is set for jpeg compression, and my raster quality is set to 25%, grayscale. We usually send to a pdf folder under the appropriate project on the file server, although I did save a few to my desktop, but that made no difference in the time or size. This method works fine with SS10, but has only become a problem in ORD. I'll keep hacking away and try to figure out what is going on.
File a Service Ticket with Support and send them your files (or a representative sample of your files). If you can write out your specific workflow for them to follow, that's even better.
This may be a corruption in your file, or a bug in the software, either way, submitting a Support Ticket gets it in front of the official eyes to find a solution.
MaryB
Mary,
After getting some other work done, I was able to get back to this problem. I'm glad you mentioned file corruption. Before submitting a ticket, I decided to look at all the files. Turns out the problem has nothing to do with the raster file attachments. I had a 2D topo file which had a field book and a terrain in it. It had no 3D model, just the default 2D. Something in that file is corrupt, or has a problem. I created a new 2D topo file, referenced the original file and copied over just the linework and cells, no civil data. After recutting sheets, the plotting is working just the way it should.
Thanks for the heads up. I'm just getting my feet wet in ORD.
I'm glad to hear you were able to get things working.
Yeah, that's strange, and I can see how that kind of file corruption could cause all sorts of strangeness.
