I have blocks in my dwg-file, which i have imported to bentley view. The blocks contains attached images and those are not displayed in the bentley view anymore?
This forum is focused on printing, so you may not find an answer here. You may want to Move this post to the regular MicroStation forum.
What version of Microstation are you using? Or are you using just Bentley View? What version of DWG are you working with? Have you converted the drawing, or are you just opening it?
MaryB
