How does you print Openroads Cross sections/profiles? ?I would like to print the cross section graphics in full black on top of grayed out gridlines.
Have previously used pen tables to search for logical named references, and Grid Line levels, and used priorities to print the reference files on top of the grid lines.
This workflow evidently does not work anymore, as the section cut graphics don't seem to obey pen tables for the most part.
Seems the only way I can target the 3d cut graphics in a pen table is by searching for the color or the level, and even then the priority is not followed, so the grid lines are always on top of the sections.
Is there a new method, or did Bentley forget about actually printing the section cuts.
ORD Connect 2020 Release 3 Update 9 - Version 10.09.00.91
Goodness, no edit button, sorry for the bad grammar.
