Hello
After our company switched to Connect Edition, we are having issues with plotting PDF's and Raster. As I can read on the forums, there are several with the same annoying issue.
The solution seems to be Rasterizing the plot, but we deal mostly in vector lines and using rasterize is a huge downgrade in quaility, quality that we need in our plots. In the good old V8i this was not an issue.
The Wiki solution is basically just a big finger to the customers in all honesty: communities.bentley.com/.../transparency-is-not-printing
Is there a new workaround that fixes this, or are we stuck here forever until Bentley actually bothers to do something about it?
Sorry for the harsh words, but it just seems that Bentley keeps downgrading their own software.
System information:
Connect Edition:Microstation Connect Edition Update 14 - Version 10.14.02.01
Operating system:Windows 10 Enterprise x6420H219042.985
PC:CPU: Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz 2.59 GHzRAM: 32,0 GBGFX: Quadro T1000SSD
Hi Jens. Can you send a sample file and print drivers?
Samir
Was there a resolution to this problem?
Print Settings -> Print Attributes - Transparency on:
https://www.youtube.com/watch?v=_5_w0rzumNU
