Hey guys, I have 3 sets of cross sections that I am needing to print in monochrome for submittal. However, 2 of the cross section sets are printing in true color even though I am specifying monochrome.
My work flow looks like this: Print Organizer > Add Files to Set > I add the input file > Select my print style > Under manually specified options, in the Advanced tab, I select Monochrome from the dropdown. When I do this, the sheets are still printing out in true color. I used this exact workflow for all 3 sets and 2 come out true color one comes out monochrome.
I am wondering if this is a setting when you first create the sheets? Any ideas or thoughts are much appreciated.
You would need to define monochrome for each of the 3 sheets.
I had the same issue going on. It works now that I changed the print to monochrome, but it only works when printing a single sheet. Any idea on how to change this for Print Organizer?
You need to right click on the sheet in the pset > Properties > Advanced > Color: Monochrome. Do this for each sheet in the set.
We just turned rasterize off.
