Have a collection of drawings all set for 40x28 paper. I have been using fence, then modify fence to grab the outside borders. I select the print button and change the paper size to 40x28. Change the color to monochrome, click the maximize button, print to file, remove the -defult-000 from the file name, select the folder and save.
Anyway to automate this more. Odd paper size will not show up in a print style so each time the 40 x 28 has to be entered.
Is there anyway to have microstation default to a folder?
Name the pdf the same as the file name?
Anthony,
Yes, you can set most of those things in a print style. First - what plot config file are you using? Are you making PDFs or going to a printer?
Tom F.
Modify your printer driver configuration file name and Add the paper size you desire.
This will use the 'MODEL NAME.PDF'
I am printing to a pdf. Using connect update 12. Only a few weeks on microstation so keep that in mind for instructions.
Tony
Really new with Microstation. Should mention I am using connect v12. The windows you showed are they for connect, as I cannot find printer driver configurations?
In the plot dialog box, go to FILE > EDIT PLOT CONFIG - that will get you to the window in Bob's post
