i have tried all the settings, image transparency is not working after taking print, please help me,is any other trick is there
attaching some pictures here
I had a similar problem with a couple files several months ago. Had to be printed from v8i to get transparency correct.
Aparna Reddy said:i have tried all the settings
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
There is a Printing Forum that is more relevant to your question. You can move your post using the More|Move button.
Answer Verified By: Aparna Reddy
Hi
MicroStation CONNECT Edition - Version 10.13.00.48 Windows x64 , Using RealDWG 2019
Tried in V8i(Microstation Selectseries10),not working, what are all settings you have changed, can you please share with me.
Have you toggled on the Rasterized checkbox in the print dialog?
For getting transparency in PDF output this checkbox must be on.
Rod WingSenior Systems Analyst
