i am trying to create a 3D PDF of this attached file. But everytime i do so MicroStation crashes. This was tried on 3 PCs so far (one running CE14), every time with the same result.The .dwg file was originally created in a software product called Emulate3D, which also uses Autodesk Real DWG technology. I hope someone can help.
Rack.dwg
Hi Florian,
Florian Scheidler said:But everytime i do so MicroStation crashes.
Yes, I see the same problem on my PC also.
Florian Scheidler said:The .dwg file was originally created in a software product called Emulate3D, which also uses Autodesk Real DWG technology.
I am curious why the file is structure in such way: Several levels of nested cells makes navigation slow and complicated. On the other hand, it's size-efficient, because when dropped to individual geometry, the size grows from 1 MB to 52 MB ;-)
Florian Scheidler said:I hope someone can help.
I think no simple and quick help exists. What I see in memory dump, created after MicroStation crashes, there is memory corruption (heap corruption) in geometry processing code. Nobody than developers is able to say whether the problem is in the code itself, or maybe the geometry is created in incorrect way (I see several such DWG files in the past).
I recommend to create Service Request and to send the file to Support team. But I assume, without analysis done by developers, it's hard to say where the real problem is.
Jan
Hi Jan,
thanks for your efforts. I created a service request and send the file to the support team.
Kind regards,
Florian
Response from Bentley Support:"I would like to inform you that this issue resulted in Defect Report 689763, and will be evaluated by the product management team for our regular CONNECT Edition updates. Meanwhile I would recommend using following workflow: Using MicroStation V8i SS10 to convert file to 3d pdf."
Answer Verified By: Florian Scheidler
Thanks a lot for sharing the issue update and the defect number.
what happens if you convert to dgn first and use the compress features and remove duplicates in the clean up.etc .. does it still crash connect?
Lorys
