Hatch pattern for concrete is changing after creating PDF in microstation. Am I missing some settings in bentley driver. I'm using Microstation SS2 version.
Attach is the pattern after creating PDF
Thanks in advance,
Yamini
what printer driver?
do you use a pentable?
Do you have overrides set to on?
Can we have a screen shot of pattern in microstation before printing ?
what settings are you using in the print dialog ie rasterise etc and under the setting too?
is your pdf printer driver for printing the pdf un modified out of the box or has it been customised?
Have you got access to an un modified version of the pdf.pltcfg to test with?
Does anyone else at your work have the same problem printing the same file or same conc pattering in a different file?
Do you have same issue with same patterning in a different file?
Lorys
