I cannot get the background to print properly to a pdf. It is a subdivision and only half of the lot lines are printing. The preview is perfect.
Specifics???
What version of product, what plot driver, pen table, design script? Are you on ProjectWise?
Can you provide a sample of your file and the plot driver or screenshots of the driver settings?
We can't help wit hthe vague information you provided
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
I am using standalone watercad version 10.03.04.05 and printing to bluebeam 2019. The background is a dxf printed from autocad. The preview prints fine and will print to a plotter but not to a pdf. I have tried microsoft pdf as well with the same result.
But, are you using a .plt or .pltcfg to print to pdf? Are you using a Windows printer by selecting a printer from the drop-down list that has a Windows icon? Are you selecting Bluebeam pdf from the drop-down menu as your printer?
You are leaving out critical information. I don't use watercad. Is that built on the CONNECT platform or v8i platform?
I am selecting bluebeam from the windows printer list. I do use connection client to manage my licensing
Sorry, I'm not able to help you out here. I have BlueBean, but I am not able to select BlueBeam pdf as a printer. My best guess would be that has something to do with the resolution being set by that print driver. There may also be some type of rendering issue using that method. I would personally make a copy of the pdf.pltcfg that is delivered with the product and modify it to create a pdf. This way at least you know that it is supported by Bentley. THe settings are also easy to adjust & refine.
Good luck. Hopefully someone with some knowledge about using the BluBeam pdf driver will hop on to help you.
