When I plot a single file from my .pset. The PDF turns out just fine. When I try to run multiple files into one PDF, Microstation freezes up. These are the errors I am getting.
any help would be great.
thanks
Hard to give advise when we do not know what version you are using, if you are using ProjectWise, or any of the .pset settings
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Sorry,
Power InRoads V8i (Select Series 10)
Version 08.11.09.918
Projectwise - Version 10.00.03.167 - Commercial Release
Do you have write access to the directory you are trying to save the file to? What if you try saving it to your local pc?
I do not have write access to the default location. I have tried plotting to the project Plot folder on projectwise and also to my PC and get the same result.
Can you post screenshots of your plot setting in Print Organizer?
