I am using OpenSite Designer version 10.09.00.91. Print organizer dialog box will not open. I receive an error PLOTDLG unloaded. I’ve tried loading PLOTDLG using key in and Print Organizer still doesn’t open. I’ve also tried replacing the PrintOrganizerSettings.xml file with one from a working station. What else can I try?
Have you recently removed another Bentley product? I've seen things like this happen after removing a different Bentley product that may be using the same resource.
I would try removing OpenSite Designer, reboot, then reinstall.
Rod WingSenior Systems Analyst
In my case, the print organizer was working just fine until I came back from a break. Suddenly I couldn't open it anymore; nothing happened when I tried. Turns out that it WAS loading but the window got magically resized as small as it would go when one of my monitors went to sleep and Windows reshuffled everything.
