I have a project that I'm trying to print to a PDF in monochrome. The drawing is a plan and elevations drawn from a point cloud. The elevations have been saved as Named Boundaries. When I try to print (to file, to printer or any other configuration) the Rasterized box is checked, the option for True color is selected and both are greyed out in the print dialog box. The same thing happens when I reference this into other drawings. This is the only drawing that is stuck like this. Does anyone have any idea what might be going on?
How are you printing the files. Are you using a .pltcfg? Are you using the same .pltcfg for all files? It's odd that it is only happening with one file. Please provide Microstation version and your workflow for printing files to pdf.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
