Did a little looking around and I can't seem to find a way to get the Microstation plot config file (*.pltcfg) on my plots using a design script.
MicroStation 8.11.09.919
Tom F.
Since design scripts were originally developed for use with IPlot, which doesn't use .pltcfg files, I wouldn't expect that it would allow for that.
You can use a pen table and a design script on the same print. Set up the text substitution in the pen table, then use the design script for the rest.
Rod WingSenior Systems Analyst
The design script "envr_variable" and "envr_value" keywords would also work, using the "MS_PLTDRVFILE_SHORT" print accounting variable (assuming you didn't want the full path; long and abbreviated versions are also available).
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v16/en/GUID-B60EC3D8-DB1A-2372-AC08-CABA037EDD8C.html
Thanks Rod, That's my backup plan. For the sake of simplicity, I'm trying to keep all my resymbolization in one file - Tom F
Andrew,
envr_variable worked perfectly.
Answer Verified By: Tom Felcone
