No MDL drive application specified in the plt file
Hi all,
One of our clients is using Microstation v8?, and has run into an error when attempting to print.
"There is no MDL driver application specified in the .plt file 'xxx.pdf'. The 'driver =' line was optional in prior versions of Microstation but is now required.
Is there a fix for this one?
