I'm using the following code in a function key to print from my border level. I use this for pdf's and prints currently in 11x17. Can't figure out why it won't do it on a letter size.
place fence; level element select C-COMM-OVHD; PRINT DRIVER HSC_DCCprint.PLTCFG; print papername letter; PRINT RICOH IM C3500; print execute
Any suggestions?
I'm not seeing a call to load the print mdl. Typically you have load the print mdl before it will accept the print key-ins.
Rod WingSenior Systems Analyst
What would a print mdl callout be?
i don't believe there are any instances where an mdl is used to print to my knowledge. there aren't any in my available apps/.ma's. It could be something I've never encountered. If this is true, i would have to call out: mdl load ".ma name"
There are two key-ins available to load the print mdl
Either one of these will load the print mdl making the PRINT key-ins available.
You don't say what version of MicroStation you are using but those two key-ins work in both V8i SS10 and CONNECT Edition.
