I was trying to print a plan. It stays at the printing status forever. I noticed that there was a small window (I pulled the window above the 'print status' and made a screenshot below). I think it is this window that causes the issue. I tried to enlarge this small window but in vain. Any ideas what happened? Thanks so much.
Do you have the Rasterized checkbox toggled on in the Print dialog?
When that is toggled on, it takes much longer to generate and submit your print.
You do not need that turned on just because you have a raster image attached.
Rod WingSenior Systems Analyst
Thanks Rod. I have the 'rasterized' option unchecked.
Does it make a difference if you turn off the display of the raster image and print the drawing without the attached raster?
The raster image is the issue. Without it, it prints well and fast. After I turn it on, it does not print at all. I left the printing process open for hours yesterday and nothing happened. It seems that Microstation jumped out a small blank window (as shown in my original post). It could be some error message but I cannot enlarge and see it.
Are you printing using a Bentley driver (.plt, .pltcfg file), or using a Windows driver?
Are you printing to a file, or direct to a printer?
