This is a recurrence problem with new version. I'm using Microstation V8i SS10 now. I created my pen table including text substitution. It works when I send it to the PDF printer, but when using print organizer and attaching the same pen table, the text substitution doesn't work. Does anybody knows what is wrong? A suggested answer before was "Check the advanced tab in Print Organizer, make sure you have your user and project set correctly" I can't find advanced tab. Thank you!
The Advanced tab is in the Print Style editor.
Are you using a Print Style when you add sheets/files into Print Organizer?
Rod WingSenior Systems Analyst
Hi Lucilia,
Lucilia said:A suggested answer before was "Check the advanced tab in Print Organizer, make sure you have your user and project set correctly
You were given the wrong answer, all you need to do, is make sure the same pen table set in the Resymbolization/Pen Tab section for the Print Style on the Main tab, then everything should work just fine.
