it seems that several (personal) settings have changed. the most important on is the plot date stamp.
I've followed all the directions I can find, with no luck.
Lisa
are you using pentables and textsubstitution ie $DATE$? is it on a non plot level by mistake ? I have this in my titleblock sheet at the inner edge of the inner border so its still in printable area...also $FILEL$ and $TIME$
the $FILEL$ is the full file path where the dgn was printed from pretty handy in back tracking pdfs and where they come from
there is also an option for user ( who opened and printed the dgn) and scale but I dont want those
Lorys
Lorys,
Thank you for helping out. No, its on a proper layer.
Due to our setup, I choose an inside border line for the plot. This has worked for 17 years ... and now, it's not.
If I choose the outside border, the plot stamp does show tho.
Hi Lisa,
Can you attach a sample DGN and a pentable so we can investigate?
I found the problem. The stamp setting for the plotter was turned off. We assume that when the plotter driver updated, it disabled some settings.
Thank you All for your time!
No worries, glad you found the solution
