This is a stretch, but here goes...In v7 there was an option in Workspace where you could dictate that text had to be printed with solid lines and not the linestyles of the level. That option has been gone since v8 when Bentley changed it so that text always printed as solid lines.We have switched over to using iCS through ProjectWise and it seems to be printing the old v7 way where it prints the text with the linestyle of the level. Bentley's support is atrociously non-responsive (seriously, I've gotten so many people involved and I can't even get "support" to respond) so I'm trying my own solutions. I want to try to see if anybody remembers the variable that was in v7 that you could set so that text had to print as solid lines and then try adding that to our current workspace so when the iCS picks up the sheet to print it picks up that variable also. No guarantee it'll work but since Bentley has literally not answered me I need to try something.So, does anybody remember what that variable was? Bentley has no documentation that I can find on this.Thank you,Chris Williams
Try this pentable I have forced all text to style 0..
I can't test it here as I don't have any examples of your text not working and no pwise environment printing setup to duplicate what you
may be using....
test.tbl
Lorys
I truly thought you were on to something but it didn't work. So far the only thing that works is going into each sheet file and setting the element to Style 0.
