can't use the printer driver configuration tool
I can't edit the print driver pdf.pltcfg file with the print driver configuration tool on Microstation Connect. I have tried to set it as the active one and edit it by going to File> edit print driver configuration tool on the printing window, but it makes it run a new Microstation window and after displays the message: Alert [] is not a recognized file format.
Parents Reply Children
