How do you create bookmarks in your pdf using the model name \ sheet name and not the file name?
I found this,but where is the ip.cfg file?
If I create a script file the variables are not supported in the print organizer file
In ip.cfg, set IP_EXTRACT_VARIABLES_ON_CREATE_PLOTS = trueWhen bringing the files into Organizer, attach a design script that contains these two lines:extract_envr_variable="PLOT_NAME"extract_envr_value=ip_model
I'm not sure its even possible, isn't that something easier done outside of MicroStation once the PDF is made?
I'm not sure handcoding all of the bookmarks with the proper name is easier than having those created automatically on printing.
But IP.cfg suggests a reference to InterPlot, which is a separate plot management software, not packaged as part of MicroStation. It definitely has capabilities beyond the standard plot drivers and pentables.
MaryB
I can go into Bluebeam and delete the bookmarks MicroStation creates and create new bookmarks,but I don't want to have to do this every time I update pdf files
Kirk
I Wish Cadland was Reality
