I have a DGN for our signing and marking plans. There are a number of elements that will not print when they show up in the sheet model? I have made sure they are not construction class, the levels are set to print in Level Manager and print fine in other sheet models. They also print fine when printed from the print dialog and not Print Organizer. See the two images below. Any help would be greatly appreciated.
Unfortunately DGN is outdated.
hh
Is there a pen table or some script defined in Print Organizer that is not defined when printing by another method?
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
