Adjust colour not print
Hi everyone!
I have a problem with printing "adjust colour".
I chose this option to change colour my reference. And it was changed on my drawing but when I printed that, the colour is not the same.  I can add that is reference from dwg. Maybe, it has influence for that.
ARY
  • Hi Andy
    Within the reference  adjust colour option, there is a tick box to print adjusted colours
    Ian
  • Hi Ian,
    The version is MicroStation CONNECT Edition - Version 10.15.00.74.
    Yes, I know that and I checked this tick box and I saw your last post about it. But it's still not working. On presenation view is good colour but on preview and on pdf file are diverse shade of greys. Not my necessary colour. Maybe it depends from levels or something like that. I'm using level overrides but it's the same and i think it dosen't matter.
  • Check preferences in the backstage. Go to <File <Settings <User <Preferences and make sure Use Color Table is checked on. This will tell Microstation to use the colors from the table of the attached file. You also need to make sure your plot driver does not have colors redefined. Since you state that the presentation view and pdf show shades of grey then something in the plot driver seems to be affecting output. Either the plot driver has colors redefined, a pen table is switching the colors or a script is being enabled. Check each of those settings first.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
