When I'm using the print organizer of Microstation Connect on the active file where the path to it has an apostrophe (') in it, the models within that file will not be added on the print organizer and I get the following message:
The process 'C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe' failed to indicate readiness within the allotted time of 120 seconds
There are workarounds:
-Removing the apostrophe in the name of the folder.
-Add that file to the print organizer through another file with a path without apostrophe
-Using Microstation V8i.
Yet I find these workarounds cumbersome, especially since it worked in V8i.
Can somebody help me with this problem?
Thanks in advance.
If it worked in V8i and does not in CONNECT log a service ticket with Bentley. Who knows if/when they'll get around to fixing it, but that's the only hope you have of getting it corrected in the software.
Out of your three workarounds you are probably stuck with picking the one that causes the least disruption to you and go with that.
Rod WingSenior Systems Analyst
