10.16.2.34
I am trying to create a .pset from the Sheet Index. I have Print Styles setup but, I am not able to select a paper size. I have a Print Style setup to use ANSI D & one to use ANSI B but, it does not matter which style I select the ANSI B is used. Is it because ANSI B is set as the default paper size in the .pltcfg?
Is there any way to change the paper size after the .pset is developed?
I ended up creating 2 plot drivers. 1 with only ANSI D paper size the other with ANSI B only.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
mwlong said:Is there any way to change the paper size after the .pset is developed?
The Printing & Plotting Forum would be a good place to post that question.
I have found that if you use the Sheet Index to create the Print Organisor setup, you lose all controls over the print/plot setup including paper size. If you manually create the print organisor you get the full control back.
= Sheet index is not fit for purpose... never has been and c. 6 years later still is next to useless.
Ian
The Sheet Index uses the paper size defined in the sheet model to determine the print paper size. That size is carried over to Print Organizer when you export the sheets in the Sheet Index to Print Organizer.
You want to have the Sheet Model paper size correct to start with as the affects scaling, positioning, etc. of your print. You can change the paper size in Print Organizer.
Your question does bring up some interesting workflow challenges, as it is not uncommon to print sheets on D Size (or larger) for public comment, then print the final plan set on B Size paper. Since you can only have one Sheet Index per WorkSet it might take some creating thinking to work around that.
Rod WingSenior Systems Analyst
I agree. In the UK we typically use a A1 as a master sheet but we print them at A3 (A3 is 50% of and A1). Using Sheet indexing we cannot do this in a simple manner. if you manually setup the PSET you get the option to change the sheet print size
