PDF Renditions from .dwg
Hi all
Keen to understand how others in the industry are overcoming the issue of creating PDF renditions for .dwg (Autocad or Civil 3D) native drawings in Projectwise. As most would be aware the PW renditions engine runs on a Microstation engine and with the conversion from .dwg to .dgn the objects in the models+drawings are typically shown incorrect, wrong colour, wrong size, etc. Civil 3D native drawings have the added hurdle of the ObjectEnabler to translate the objects correctly, adding further difficulty.
The BATCHPLOT command on offer but does not solve the issue of replacing the PDF rendition files (which have the associated Metadata) with those PDF created natively in .dwg. All very time consuming and with the element of risk handling many files.
