Hey! Sanjay Metal India is where I work
While sending an attachment on email, the colour of the attachment fades
I'm don't think this is a printing issue. Anything that happens after the print is created is a problem with whatever software you are using. Microstation responsibility is finished when the print file is created.
What format are you printing to? When you open your printed file, does it look correct?
MaryB
Your default setting could be set to low, making you get those weak prints. In the event that your printer has ink/toner thickness settings, you ought to have the option to find them whenever you've tapped on your printer in 'Gadgets and Printers, so that's why print faded after washing.
