If I given single sheet print via print option I'm able to give the print, but at the same time when I'm giving print from print organizer, I'm getting an error in message centre as
Error writing print file 'C:\Users\<name>\AppData\Local\Temp\xyz.tmp|C:\Temp\tmp\xyz\xyz.pdf'
Error was detected inside the Adobe PDF library method' PDDocSaveWithParams (C:\temp\tmp\xyz\xyz.pdf)'
Can anyone please suggest what will be the problem?
I would appreciate your help with this.
Frank X
I get an error like that if I print to a filename that is open with Acrobat.
The following discussion had previously advised the following should fix this issue.
Error printing with pdf.pltcfg and Adobe
You can fix this issue via the following steps:
set Enable Measuring and Enable Georeferencing to "Off" in the PDF.PLTCFG.
