Plotting to PDF from Microstation
Hello All,
We are trying to deprecate the print to plotter functionality and replace the same with Print to PDF. Our Users have Microstation Select Series 10 , Descartes and IPLOT Organizer on the System. Although IPLOT has Export to PDF option , we are not getting same result as with print to plotter using the PEn table and design script files.
Other Question I have is , is there a way to use command line to generate PDF files using IPLOT ? I havent been able to find any documentation regarding the same and one of the old forum's from 2014 here mentions that its not feasible. Link of the article :
https://communities.bentley.com/products/projectwise/w/publishing-wiki/14861/can-i-create-pdf-output-files-using-the-iplot-command-line
Any help is highly appreciated.
Prateek
