PRINTORGANIZE PRINT SELECTION KEY IN NOT WORKING
I am trying to write a script to create PDF binders based off sub folders in a .pset.  I am able to print everything in the pset with no issue, but when I try to print specific folders I am unable to. I am using V8i SS10, the .
oDGN.CadInputQueue.SendKeyin("mdl load bentley.microstation.printorganizer.dll")
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER NEW")
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER APPLYPRINTSTYLE ALL E COLOR")
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER ROOTFOLDER")
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER ACTIVEFOLDER CH00"
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER PRINTDESTINATION d:\temp\new folder\CH00.pdf")
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER SUBMITAS SINGLE")
oDGN.CadInputQueue.SendKeyin("PRINTORGANIZER PRINT SELECTION")
Basically I want to print only the items in the CH00 folder as shown, but I can only get it to print out everything in both CH00 and CH12. Is PRINTORGANIZER PRINT SELECTION supposed to do this or is this something I am doing wrong and not how this function works? Right now the only solution I have is to create a pset for each subfolder instead of using one pset for everything, but I was trying to avoid that since I already have the pset created because I also need to output everything as a single binder and it takes a few minutes to pull in/print 1000 or so dgns so I am trying to avoid some redundancy.
Stephen
