I'm adding a file to print organizer that has multiple models and each models there are multiples sheets to print. I have defined the print area as fence tab defined from cell or even defining from shape, it doesn't keep the settings and printing just one random sheet. How can I print several sheets in several models in one file?
I am running Microstation v8i SS10. Thank you!
You need to create a .dgnlib and have your print styles defined in this file. Make sure MS_DGNLIBLIST or MS_DGNLIBLIST_PRINTING is pointing to this file. This allows the print styles to be available to all users.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
When I try to define my print styles in PO tools<Define Print Styles the window to set it up doesn't pop up anymore, I don't know what happened. I looked MS_DGNLIBLIST and didn't change anything, it's all set.
Maybe the dialog for Print Styles is off screen somewhere. Try reducing your resolution to the lowest possible on each monitor and see if it is out in space. If so, drag it back before the resolution changes back to normal.
Now in Message Center is saying "PLOTDLG unloaded" What is it mean?
Lucilia said:"PLOTDLG unloaded"
That message appears when you have the normal Plot Dialog open. Upon closing the dialog the message center just notes that it was unloaded. I don't believe that has anything to do with PO
