When printing in OpenRoads, my referenced text and linestyles print in a jagged fashion even though they display right in the default model. Text copied from the referenced file into the design file prints correctly. Is there any fix for this? Thank you!
Would you be able to provide us a sample of both your active drawing and your reference file, your PLTCFG file as well as any pen tables or design scripts you use for plotting, and possibly your font file if it isn't a standard (delivered) font?
It will be much easier to troubleshoot if we can see for ourselves what is going on. An image doesn't really tell us anything - there are a few potential settings that might be in play.
MaryB
