Would anyone know how to fix this? OpenRoads Designer
When creating a PDF in OpenRoads Designer CONNECT Edition with ProjectWise Rendition the named view boundaries cross section line work gets messed up. See attached pdf. The cross sections are created on a vertical sheet as shown below in orange. When running these thru Iplot or rendition with a rotation of 90 degrees the PDF get messed up like this in the pdf. In Iplot there is no way to set the sheet orientation to portrait. Setting to portrait in MicroStation plotting works for these vertical sheets. Is there any way to fix this to work in ProjectWise Rendition and Iplot.
ORD
Thank you,
I got it. Everything working fine now.
Answer Verified By: Garry Spivey
Hi Garry, I'm about to go trough the same process, would you mind sharing some tips about what was the problem and how you solve it?
#In the Set file the
paper_size = noneplot_area = Sheet#MODEL = IP_SHEETDEF_MODELS #uncomment if you have multiple sheet models in one file and ProjectWise rendition is setup to print multiple sheet models from one file.rot = 0 #roatation has to be zero otherwise the cross section 3d views get messed up.full_sheet = falseorigin = 0.000000,0.000000 xsize = 11ysize = 17
data_rescale = 1.000000,1.000000plot_rescale = 1.000000,1.000000
nodisplay[iplot_all] = [points, construction, enter_data, ref_boundaries, text_nodes]display[iplot_all] = [area_fill,dimension,line_styles,pattern,weight]nofast[iplot_all] = [text, font, curve, cell]
# Hope this helps you.
