Some features not plotting from print organizer, but do when sheet model is plotted individually
Good morning. We have been having a recent issue in MicroStation ORD 2021 Release 1 with print organizer. We noticed that one certain feature we need to show up on our PDF plots are not showing up when plotted using print organizer, but it is if we plot directly from the sheet model itself. The strange thing this is, other identical features, on the same levels, etc, that show up on other sheets are plotting correctly
Here is what the sheet model looks like itself:
Here is what the PDF looks like when plotted using print organizer:
Here is what the PDF looks like when the sheet model is plotted individually:
Both PDFs are using the same print driver, etc. I also tried to delete and reload that specific sheet model into the sheet index/print organizer and that did not work.
Any idea what is causing this or how to fix it?? Thanks in advance
  • Don't know why you don't see ORD in the list
    As far as the plotting issue, it can be difficult to track down on our end as we do not have access to your files & workspace. Maybe try deleting the print definition for that sheet and add it back to the .pset?
    It could also be something corrupt in that particular sheet model as well.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
