My pset's get stuck on this window when i change things in the properties and it will not disappear until I force the program to close. Anyone know the cause of this?
Sometimes Microstation takes way longer to generate a print preview than it does to actually print the sheet. This has been an issue long before ORD appeared.
What I recommend: Sit there and stare at that box. Go get a coffee from a coffee shop in a distant city. Read the first chapter of a new book. Then check back and the box should hopefully be gone and you should see a preview of your sheet in the bottom right corner. Now uncheck the box that says "Show design in overview". Save the PSET, save the DGN, save settings, save again, save settings, save again, restart ORD, and come back and your Print Organizer won't be bogged down by these automatic print previews ever again. When I want a print preview from Print Organizer I just print to a throwaway PDF on my desktop.
Bentley, please don't remove/change or try to "improve" Print Organizer. It's great and you're great. I apologize for my tone.
Lol. Thank you for the help. I will forever keep that box unchecked. I think Bentley forgives you for your tone for all the trouble we are caused on a regular basis.
