Is there a code to put in a Pen Table or DSCRIPT file to tell it that Construction Class elements should be No Plot? We use a DSCRIPT file to pass most of our information to iCS for running renditions, and I'd like to add a code to make sure that Construction Class elements don't print since ORD puts lots of items on construction class.Thanks,Chris
I solved this by adding the line -nodisplay[IPLOT_ALL]=[construction] to the SET file that iCS looks at when running renditions.
Answer Verified By: Christopher Williams
