We have an .xwms file we are using for a background aerial in a project. I have not worked with these files in the past. It is currently displaying/printing in color. The "Print raster in grayscale" option on the Modify Properties window in Print Organizer is not seeming to have an affect on the aerial printing in grayscale. Is this because it is an .xwms file? Is there a way to print .xwms files in grayscale? I am using V8i, SS10.
Sean
I have attached an.xwms file to a dgn and using Print Organizer with "Print raster in grayscale" option on the Modify Properties window been able to generate a grey scale result in both MicroStation V8i SS10 and CONNECT Edition Update 17.2
Here are the settings I used, for reference.
Do you have the same issue with other raster formats IE are they previewed Grey Scale?
Is the issue peculiar to this one *.xwms?
If still an issue, would it be possible to post a small sample file/image for review.
Carl Myhill
Technical Support Engineer
Bentley Systems
Thanks for your reply. I was able to select grayscale Color Options along with the other settings shown and get it to print correctly.
