All,
I need to change the "Default Line Cap" setting to "Flat" but I can't seem to find any way to do in iPlot / Renditions. We use .set and .dscript files with iPlot, but after looking through the documentation, I cannot find a setting or means to set this value.
I can see the setting when printing directly through MSCE inside the .pltcfg file under Base Properties > General > Default Line Cap.
Thanks in advance.
The design script assignment keywords you're looking for are "endcap" and "midline_joint."
Assignment Keywords (bentley.com)
Matt Eiben
Answer Verified By: dkleinot
